This is my first tutorial. Here I'm keeping it brief, and mostly listing the links you need to get started. In my next post(s), I'll write about how to render a makehuman character in renderman, written for the perspective of someone who already understands Cycles.
Basically: Renderman is a ray tracing renderer developed by Pixar and was (relatively) recently made available in Blender. Some benefits to trying it out:
1) Comes with a physically based uber shader
2) Seems to be more efficient than cycles for complex scenes/lighting
Follow the instructions here to install renderman on your computer. This installs the renderer itself, not the addon that allows it to interface with blender.
https://renderman.pixar.com/view/get-rendermanThe caveats are that you need to make a renderman forum account in order to register renderman, and that it's free, but only gives you a non-commercial license.
Their FAQ page has more details on the terms of the non-commercial license:
https://renderman.pixar.com/view/dp25849After running the renderman installation exe, you should be able to install the blender plugin the same way you would any other addon (by using the install from zip feature).
https://github.com/bsavery/RenderManForBlender/releasesThe renderman site also has instructions on getting started in blender (no login required to see this page, but you do need to log in to see the forums)
https://community.renderman.pixar.com/a ... ender.htmlAfter installing and enabling the renderman (aka PRMan) addon, renderman should be in the drop down list of available renderers along with blender internal and cycles.
Things to note when addon is enabled:
There's a renderman sidebar on the left pop up tab of the 3d view window. You can initialize the material library browser in there... for me it works, and I can look at the pretty thumbnails, but it gives me an error if I try to apply or save a material (the preset browser works in maya however).
Note that you can still select the cycles nodes when PRMan is the active renderer, but blender will crash if you hook up a cycles shader to the PRman output. But even when the active renderer is set to cycles, as long as your PRMan addon is enabled, you can still see and select the PRMan nodes anyway (Blender will probably crash horribly if you try to use them in cycles), and when you click the gray dot in the cycles material editor (in the properties window), it will add a PRMan texture node. You have to go to the node editor and manually hook up a cycles image texture node, or just disable the PRMan addon while using cycles. (unless there are glitches I don't know about.)
