New Wiki Section on Making Custom Vertex Groups
Postby MTKnife » Fri Nov 04, 2016 3:32 am
I've just added to the clothes documentation a section on using custom vertex groups to eliminate the distortions that often occur when clothes are put on a model shaped differently than the target used to create them in MakeClothes. The text in question is adapted from an earlier forum post of mine. Looks like it's not showing up yet, but it should show up here:
http://www.makehumancommunity.org/wiki/ ... akeClothes
MTKnife
Re: New Wiki Section on Making Custom Vertex Groups
Postby RobBaer » Fri Nov 04, 2016 8:21 am
Thanks for working on this, but I think something went wrong with the submit. At least I'm not finding anything at the link you provided.
Are you sure that your work actually got submitted, and that you did not just look at a preview? It should "show up" immediately, I think, if the submission occurred properly. One thing that is easy to do is go in to preview and then forget to save the page (speaking from sad personal experience :cry: )
Postby joepal » Fri Nov 04, 2016 9:04 am
Looks fine to me, if the section is "What if automatic vertex groups don't work?" and so on:
Are these the changes you are talking about, or is there something more which is not visible here?
Postby joepal » Fri Nov 04, 2016 9:06 am
Looks to me as if you've added your changes to http://www.makehumancommunity.org/wiki/ ... on:Clothes, whereas you mention http://www.makehumancommunity.org/wiki/ ... akeClothes in the forum post here. So I'm thinking you've mixed up which page you saved stuff to.
A hint which might be helpful if things seem to have get lost: Click the "recent changes" link in the menu to the left (I think everyone have access to this). If anything whatsoever got submitted, you'll see it listed here. If your change is not listed, then something really did go wrong.
Postby MTKnife » Fri Nov 04, 2016 11:28 pm
The confusion seems to arise from the fact that the same text is repeated on both pages. Which is the right one?
MTKnife
Postby Aranuvir » Sat Nov 05, 2016 12:11 am
MTKnife wrote:The confusion seems to arise from the fact that the same text is repeated on both pages. Which is the right one?
I'd say the text you have edited and I'd propose to merge the texts.
Return to Tutorials
