Request: .mhmat format description
Postby learning » Tue Jan 26, 2016 11:36 pm
Can someone make a description of .mhmat format with all its possible options and how they work? Preferably on the wiki, and I think it's generally better to use wiki for the documentation of the sort. Right now it's very much useless, admittedly. Later probably we'll need descriptions of all the rest of MH file formats.
learning
Re: Request: .mhmat format description
Postby duststorm » Wed Jan 27, 2016 12:46 pm
I'll see if I can create an example mhmat file that contains all properties and put it on the wiki.
Other than that, I don't think I can help much. I might have a biased perspective on this, as I was the one who designed it, but really the material format is nothing exotic, and should feel familiar right away if you are accustomed to the standard rendering equation, or have some experience with OpenGL, DirectX, shaders or other material systems.
So I'll leave the rest of the documenting to the community.
Postby duststorm » Wed Jan 27, 2016 4:35 pm
I took the time to write most of it down, here you go: http://www.makehumancommunity.org/wiki/ ... ial_format
Postby learning » Thu Jan 28, 2016 1:12 am
Wow, thank you, that's very helpful. The only thing I still don't understand is how the specular properties in blender (hardness etc) relate to ones in .mhmat Everything else I've pretty much got.
learning
Postby duststorm » Thu Jan 28, 2016 9:23 am
learning wrote:The only thing I still don't understand is how the specular properties in blender (hardness etc) relate to ones in .mhmat
In mh materials you can define the specular color and hardness or shininess component.
The model used is https://en.wikipedia.org/wiki/Phong_reflection_model
Return to Tutorials
