Export mhx2 to file fails
Postby hausmeister » Tue Nov 03, 2020 7:43 pm
I am using Linux Mint 19,2 and 9_export_mhx2 from mhx-mh-latest.zip
I can not export with mhx2 to a file, but e.g. collada (.dae) works.
I get the following error:
File "./core/events3d.py", line 211, in callEvent
method(event)
File "./apps/gui/guiexport.py", line 112, in onFileSelected
exporter.export(gui3d.app.selectedHuman, filename)
File "plugins/9_export_mhx2/__init__.py", line 56, in export
mh2mhx2.exportMhx2(filename("mhx2"), cfg)
File "plugins/9_export_mhx2/mh2mhx2.py", line 98, in exportMhx2
mesh.material.setViewPortColor(getSkinBlender().getDiffuseColor())
AttributeError: 'Material' object has no attribute 'setViewPortColor'
hausmeister
Re: Export mhx2 to file fails
Postby RobBaer » Wed Nov 04, 2020 12:16 am
Could you tell us which MakeHuman you are running. Is it 1.1.1 or the 1.2.x release candidate?
Also, could you tell us where/when/how/version for your version of mhx2?
Postby hausmeister » Wed Nov 04, 2020 7:07 pm
It is Makehuman 1.1.1_1 for Linux mint (contained as a package)
In mh2mhx.py I can read "Mhx2 Version = 0.31
hausmeister
Postby RobBaer » Wed Nov 04, 2020 9:03 pm
My sense, given the "older nature" of your MakeHuman installation, is to recommend that you start by upgrading to the latest 1.2.0 version of MakeHuman. There is a release candidate for Windows that will become final within days that you could download and try right now. However, since you are on Linux Mint, you have two choices. One is to install from source, but there is some possibility of having to play around with dependencies.
The better is to wait until final ppa for Linux is announced (theoretically within days). Loki has gone through the process already and I think may have some tips for how to get the "recommends" part of things with the new Mint policies. He's been there, done that already.
Postby loki1950 » Wed Nov 04, 2020 10:03 pm
Thanks for the mention Rob I use he ppa and it is indeed version 1.2.0 and it is working as advertised.Mint has changed it's mind about "recommends" so that is no longer an issue.
Postby hausmeister » Thu Nov 05, 2020 4:59 pm
Thank you for your efforts!
hausmeister
Postby hausmeister » Thu Nov 05, 2020 5:28 pm
With makehuman 1.2.0 everything works fine!
hausmeister
