I'm trying to work out how to use makehuman and blender together.
I'm using makehuman Alpha6 and blender 2.57.0 under windows 7.
On the way, I've found a few problems. Some I've resolved, but the following are outstanding...
1st problem found: in MH, settings -> skin shader causes MH to die.
phong shader setting is accepted.
Not sure if I should be using this, or 'no shader.' Tried both. Phong shader seems to work quite well.
Then files -> export, and select blender exchange (mhx).
Tried 'use config options' (2nd problem - not sure where these are set, or how to change them, if they can be changed); also tried gui options, selecting 'version 2.5,' 'expressions' and 'use mhx rig.'
Character imports into blender nicely, it seems. Gradually getting to grips with posing the rig in blender.
3rd problem:
But I can't seem to make sliders do anything, except face sliders seem to work. I'm not sure how the arm/leg Fk/IK and finger sliders are supposed to be used? The layers don't seem to correspond to the document; has it all changed?
4th problem
BTW how do I make use of 'texture' from library? Is this implemented yet? I can see 3 1/2 rows to choose from; it seems there are more options there somewhere, but I can't seem to scroll down at all to see them.
Thanks for your help
/Gary
