Opensim & SL Rigs
Opensim & SL Rigs
Postby Elvaerwyn » Fri Dec 08, 2017 1:58 pm
The new*ish bento skeleton(for use in opensim/sl and similar universes)uses tail and wing bones-also hinds, this skeleton works well with flying, quadruped, and tails, antennae etc that one might choose to append a character/avatar with. Blender and its addons, manage to work with this skeleton for porting/conversion. However, this becomes quite clunky quickly when working with makehuman builds and assets back and forth. Actually in between updates on a blender addon, the porting process was very broken, and had to be worked around. I have seen in past others stating a skeleton file(rig) including the bento bone structure for use in makehuman was not only possible but most likely forthcoming? If not I would like to make a formal request from a rig builder for this asset upload, and if there is anything I can do to help would love to do just that! Ty.
Re: Opensim & SL Rigs
Postby Beacara » Thu Dec 21, 2017 10:17 am
Hello! No idea why, but I found no way to answer your PM. So this way:
The rigs posted in "User contributed assets" were created by MakeHuman. I'm not a rig-creator myself.
The bento-rig:
Up to now there is no good working solution, Avastar 2.0 has not managed to give a conversion that is working out of the box without many tweaks. What can be a workaround: Create a new T-pose (mhx2 to blender) with fingers and facebones similar to the bentobones, export as bvh to Makehuman as a new pose, re-export to blender with the opensimrig, unbind, delete the rig, bind to the bentorig. Okay, I admit it is a bit more complicated because you have to consider the eyes separated... When you use Avastar, maybe you can ask Gaia Clary for help.
Beacara
