MHX2 plug in for Mac is not recognized
Postby edgrimaldi » Thu Sep 15, 2016 11:58 am
Hello,
I just downloaded the latest version of MakeHuman as well as the MHX2 plugins for MH and Blender. I found the MakeHuman plugins folder by browsing the application's package contents (app>Contents>PlugIns) and placed the folder [9_export_mhx2] there. When I restart MakeHuman and attempt to export a model, there is no mhx or mhx2 mesh format available as I expected to find. In the Mesh Format box, there is only Collada(dae), Filmbox(fbx), Wavefront(obj), Ogre3D, and Stereolithography(stl).
I have confirmed I am running the only instance of Make Human (version 1.1.0) installed on my machine, and interestingly, as the program loads up and the install process is echoed on the splash screen, for a very brief moment, it appears that [9_export_mhx2] is attempting to install. (for whatever that's worth)
Also, permission on that folder are set to read and write for everyone, so that shouldn't be an issue either.
Any help would be greatly appreciated.
Thanks!!
edgrimaldi
Re: MHX2 plug in for Mac is not recognized
Postby Aranuvir » Thu Sep 15, 2016 1:19 pm
Are there any error massages in the log?
Postby loki1950 » Thu Sep 15, 2016 8:55 pm
While you have makehunam open go to the settings/plugins tab a check that there is a check mark beside 9_export_mhx2 on the plug-in list is so then it should load if not click the box to enable it.If that still does not give you mhx2 the please find the log files so we can track it down properly they can be found at /Users/USERNAME/Documents/makehuman/v1 just copy/paste it between [code] tags so that it's differentiated from the main text of your post.
Postby redredred » Sat Oct 01, 2016 10:52 pm
loki1950 wrote:While you have makehunam open go to the settings/plugins tab a check that there is a check mark beside 9_export_mhx2 on the plug-in list is so then it should load if not click the box to enable it.If that still does not give you mhx2 the please find the log files so we can track it down properly they can be found at /Users/USERNAME/Documents/makehuman/v1 just copy/paste it between code tags so that it's differentiated from the main text of your post.
Hi, I'm having the same problem and have been through the same checks.
Folder 9_export_mhx2 is installed at app/contents/plugins and is read/write permission
Only one copy of makehuman on the system
Running on osx 10.10.5
No errors are reported in the log. Below is a full copy of the log.
Thanks.
Setting language to english
Initializing default theme first.
Theme default version 1.1.0
Loaded theme data/themes/default.mht
Using Qt system style macintosh (aqua)
Loading human
Loading binary mesh data/3dobjs/base.npz.
Loading material from file data/skins/default.mhmat
VectorUniform(AdditiveShading) = [ 0.]
Shader: adding built-in uniform gl_NormalMatrix
Shader: adding built-in uniform gl_ModelViewProjectionMatrix
Loaded vertex weights MakeHuman weights from file /Applications/MakeHuman.app/Contents/Resources/data/rigs/default_weights.mhw
Loading scene
Loading scene file: data/scenes/default.mhscene
Loading main GUI
Assigning setting loaddir value /Users/red/Documents/MakeHuman/v1/models that was loaded before the setting was declared.
Assigning setting savedir value /Users/red/Documents/MakeHuman/v1/models that was loaded before the setting was declared.
Assigning setting exportdir value /Users/red/Documents/MakeHuman/v1/exports that was loaded before the setting was declared.
Loading plugins
Importing plugin 0_modeling_0_modifiers
Imported plugin 0_modeling_0_modifiers
Loading plugin 0_modeling_0_modifiers
Loading modifiers from data/modifiers/modeling_modifiers.json
Attempting to load targets from NPZ file.
1258 targets loaded from NPZ file succesfully.
Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
Loaded plugin 0_modeling_0_modifiers
Importing plugin 0_modeling_8_random
Imported plugin 0_modeling_8_random
Loading plugin 0_modeling_8_random
Loaded plugin 0_modeling_8_random
Importing plugin 0_modeling_9_custom_targets
Imported plugin 0_modeling_9_custom_targets
Loading plugin 0_modeling_9_custom_targets
Loaded plugin 0_modeling_9_custom_targets
Importing plugin 0_modeling_a_measurement
Imported plugin 0_modeling_a_measurement
Loading plugin 0_modeling_a_measurement
Loading modifiers from data/modifiers/measurement_modifiers.json
Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
Loaded plugin 0_modeling_a_measurement
Importing plugin 0_modeling_background
Imported plugin 0_modeling_background
Loading plugin 0_modeling_background
Loaded plugin 0_modeling_background
Importing plugin 2_foot_posing
Imported plugin 2_foot_posing
Loading plugin 2_foot_posing
Loaded plugin 2_foot_posing
Importing plugin 2_posing_expression
Imported plugin 2_posing_expression
Loading plugin 2_posing_expression
Loaded plugin 2_posing_expression
Importing plugin 3_libraries_clothes_chooser
Imported plugin 3_libraries_clothes_chooser
Loading plugin 3_libraries_clothes_chooser
Loaded plugin 3_libraries_clothes_chooser
Importing plugin 3_libraries_eye_chooser
Imported plugin 3_libraries_eye_chooser
Loading plugin 3_libraries_eye_chooser
Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
Loading binary proxy data/eyes/high-poly/high-poly.mhpxy.
Loading proxy file: data/eyes/high-poly/high-poly.mhpxy.
Loading material from file /Applications/MakeHuman.app/Contents/Resources/data/eyes/materials/brown.mhmat
Loading binary mesh /Applications/MakeHuman.app/Contents/Resources/data/eyes/high-poly/high-poly.npz.
Loaded plugin 3_libraries_eye_chooser
Importing plugin 3_libraries_eyebrows
Imported plugin 3_libraries_eyebrows
Loading plugin 3_libraries_eyebrows
Loaded plugin 3_libraries_eyebrows
Importing plugin 3_libraries_eyelashes
Imported plugin 3_libraries_eyelashes
Loading plugin 3_libraries_eyelashes
Loaded plugin 3_libraries_eyelashes
Importing plugin 3_libraries_material_chooser
Imported plugin 3_libraries_material_chooser
Loading plugin 3_libraries_material_chooser
Loaded plugin 3_libraries_material_chooser
Importing plugin 3_libraries_polygon_hair_chooser
Imported plugin 3_libraries_polygon_hair_chooser
Loading plugin 3_libraries_polygon_hair_chooser
Loaded plugin 3_libraries_polygon_hair_chooser
Importing plugin 3_libraries_pose
Imported plugin 3_libraries_pose
Loading plugin 3_libraries_pose
Loaded plugin 3_libraries_pose
Importing plugin 3_libraries_proxy_chooser
Imported plugin 3_libraries_proxy_chooser
Loading plugin 3_libraries_proxy_chooser
Loaded plugin 3_libraries_proxy_chooser
Importing plugin 3_libraries_skeleton
Imported plugin 3_libraries_skeleton
Loading plugin 3_libraries_skeleton
Loaded plugin 3_libraries_skeleton
Importing plugin 3_libraries_teeth
Imported plugin 3_libraries_teeth
Loading plugin 3_libraries_teeth
Loaded plugin 3_libraries_teeth
Importing plugin 3_libraries_tongue
Imported plugin 3_libraries_tongue
Loading plugin 3_libraries_tongue
Loaded plugin 3_libraries_tongue
Importing plugin 4_rendering_9_viewer
Imported plugin 4_rendering_9_viewer
Loading plugin 4_rendering_9_viewer
Loaded plugin 4_rendering_9_viewer
Importing plugin 4_rendering_opengl
Imported plugin 4_rendering_opengl
Loading plugin 4_rendering_opengl
Assigning setting rendering_width value 800 that was loaded before the setting was declared.
Assigning setting rendering_height value 600 that was loaded before the setting was declared.
Assigning setting GL_RENDERER_SSS value False that was loaded before the setting was declared.
Assigning setting GL_RENDERER_AA value True that was loaded before the setting was declared.
GL Extension GL_ARB_framebuffer_object available
Chose alternate: glGenRenderbuffers from glGenRenderbuffers, glGenRenderbuffersEXT
Chose alternate: glBindRenderbuffer from glBindRenderbuffer, glBindRenderbufferEXT
Chose alternate: glRenderbufferStorage from glRenderbufferStorage, glRenderbufferStorageEXT
Chose alternate: glGenFramebuffers from glGenFramebuffers, glGenFramebuffersEXT
Chose alternate: glBindFramebuffer from glBindFramebuffer, glBindFramebufferEXT
Chose alternate: glFramebufferRenderbuffer from glFramebufferRenderbuffer, glFramebufferRenderbufferEXT
Loaded plugin 4_rendering_opengl
Importing plugin 4_rendering_scene
Imported plugin 4_rendering_scene
Loading plugin 4_rendering_scene
Setting rendering_width is already declared. Adding it again has no effect.
Setting rendering_height is already declared. Adding it again has no effect.
Loaded plugin 4_rendering_scene
Importing plugin 5_settings_0_settings
Imported plugin 5_settings_0_settings
Loading plugin 5_settings_0_settings
Theme makehuman version 1.1.0
Loaded theme data/themes/makehuman.mht
Loaded Qt style data/themes/makehuman.qss
Loaded plugin 5_settings_0_settings
Importing plugin 5_settings_mouse
Imported plugin 5_settings_mouse
Loading plugin 5_settings_mouse
Loaded plugin 5_settings_mouse
Importing plugin 5_settings_shortcuts
Imported plugin 5_settings_shortcuts
Loading plugin 5_settings_shortcuts
Loaded plugin 5_settings_shortcuts
Importing plugin 6_help
Imported plugin 6_help
Loading plugin 6_help
Loaded plugin 6_help
Importing plugin 7_expression_mixer
Imported plugin 7_expression_mixer
Loading plugin 7_expression_mixer
Loaded plugin 7_expression_mixer
Importing plugin 7_logging
Imported plugin 7_logging
Loading plugin 7_logging
Loaded plugin 7_logging
Importing plugin 9_export_bvh
Imported plugin 9_export_bvh
Loading plugin 9_export_bvh
Loaded plugin 9_export_bvh
Importing plugin 9_export_collada
Imported plugin 9_export_collada
Loading plugin 9_export_collada
Loaded plugin 9_export_collada
Importing plugin 9_export_fbx
Imported plugin 9_export_fbx
Loading plugin 9_export_fbx
Loaded plugin 9_export_fbx
Importing plugin 9_export_light
Imported plugin 9_export_light
Loading plugin 9_export_light
Loaded plugin 9_export_light
Importing plugin 9_export_obj
Imported plugin 9_export_obj
Loading plugin 9_export_obj
Loaded plugin 9_export_obj
Importing plugin 9_export_ogre
Imported plugin 9_export_ogre
Loading plugin 9_export_ogre
Loaded plugin 9_export_ogre
Importing plugin 9_export_stl
Imported plugin 9_export_stl
Loading plugin 9_export_stl
Loaded plugin 9_export_stl
Importing plugin 9_export_uvmap
Imported plugin 9_export_uvmap
Loading plugin 9_export_uvmap
Loaded plugin 9_export_uvmap
Loading GUI
showing category Modelling
showing task Macro modelling
Loading theme
Applying targets
Updating skeleton joint positions
Done baking animations
Loading macro targets
Loading done
Creating new texture for dynamic image data/litspheres/adaptive_skin_tone.png.
initTexture: 256, 256, False
Creating new texture for image /Applications/MakeHuman.app/Contents/Resources/data/eyes/materials/brown_eye.png.
initTexture: 1024, 1024, False
Creating new texture for image /Applications/MakeHuman.app/Contents/Resources/data/litspheres/skinmat_eye.png.
hiding category Modelling
showing category Files
hiding task Macro modelling
showing task Load
hiding task Load
showing task Export
hiding category Files
showing category Settings
hiding task Export
showing task General
hiding task General
showing task Plugins
hiding category Settings
hiding task Plugins
showing task Export
showing category Utilities
hiding task Export
showing task Logs
redredred
Postby loki1950 » Sun Oct 02, 2016 2:25 am
So is 9_export_mhx2 on the plug-ins list on the settings/plugins tab and the log you posted confirms that it did not even try to load mhx2 at all.Not a Mac user so I'm flying on instruments so to say :? just for sure check the contents of the 9_export_mhx2 folder there should be 6 .py file if and when it loads there will be 12 files as the py files get compiled to pyc files BTW the folder may have the right permissions but do the individual files also they should be executable which a separate permission on Linux not sure about OSX.
Postby RobBaer » Wed Oct 05, 2016 3:17 pm
Looking at your log, I think the right place to put the 9_export_mhx2 folder is:
/Applications/MakeHuman.app/Contents/Resources/Plugins/
To navigate there with the finder you may need to control click on MakeHuman in the Applications folder and select "show package contents". Then drill down.
Postby mooncaine » Fri Feb 24, 2017 6:01 pm
So, has anyone every gotten it to work on a Mac yet? I tried all suggestions in this thread, but MHX2 still isn't an available option in MakeHuman 1.1.0.
I copied the files to the "PlugIns" folder (note that the folder inside the Makehuman package is NOT spelled "Plugins" but I tried it both ways).
I ensured that I have execute permissions (they didn't have the x permission until I changed permissions via chmod).
As I noted, I tried renaming the PlugIns folder to match the instructions I've seen online. Same result. MHX2 export is not available.
Anyone found the secret sauce that makes this sandwich work?
mooncaine
Postby mooncaine » Fri Feb 24, 2017 6:19 pm
Never mind, I found my error. The error was mine.
I was looking at the wrong folder. That's why the spelling didn't match.
When I copied the 9_export_mhx2 folder to the plugins folder here, it seems to be working:
Macintosh HD/Applications/MakeHuman.app/Contents/Resources/plugins
mooncaine
Postby RobBaer » Sat Feb 25, 2017 8:19 pm
Thanks for reporting back. OSX is not a commonly used platform for any of the developers, so your report will be a nice starting place for helping other MH users on the Mac.
Postby dstoddart » Thu Apr 16, 2020 8:28 pm
RobBaer wrote:Thanks for reporting back. OSX is not a commonly used platform for any of the developers, so your report will be a nice starting place for helping other MH users on the Mac.
Several years after this post I am also struggling with MHX2 on a mac, when I go to export I get the following error:
File "./core/events3d.py", line 211, in callEvent
File "./apps/gui/guiexport.py", line 112, in onFileSelected
File "plugins/9_export_mhx2/__init__.py", line 51, in export
File "plugins/9_export_mhx2/mh2mhx2.py", line 40, in <module>
ImportError: No module named uuid
Any advice would be greatly appreciated.
dstoddart
